HuanYang VFD speed control too high
Posted: Mon May 08, 2023 11:05 pm
Making huge strides in my build. I have my spindle up and running, start, stop, fwd, rev and alarm all work. Speed changes in MDI make it spin faster and slower when changed. Problem is that the 24k RPM spindle speed (and VFD) are far too fast. S22000 maxes it out at 24000. S6000 is around 6800. Speeds are stable, so I don't think it is a noise issue. The 0-10v wires are in CAT8 double shielded cables, drained to ground. If it was wire resistance, the voltage would be lower, and this seems like the opposite problem.
I ran the bench test multiple times with different meters, all within a hundredth of a volt, so acorn output appear to be good. I suspect the VFD is simply misinterpreting the input.
I experimented with the 4 reference voltage values in the bench test program and can slightly improve the desired vs actual speeds, but at best 23000 requested spins 24000.
Set it all back to my true measured values, and experimented setting the max spindle speed in cnc12. I have it on 25250 now, and most speeds are within a couple hundred RPM, plus or minus. Many speeds are only 25-50 rpm off.
Is this an ok workaround? Will it cause any other issue? Anyone had this issue and solved it differently? Any other fix I should try? Thinking maybe inserting a trim pot in the 0-10v line, but if the kludge above is ok, less parts is a good thing.
