Translation of cnc12 Traduction de cnc12
Hello I would like to know how to change the words and add some on cnc12
Bonjour je voudrais savoir comment faire pour changer les mots et en rajouter sur cnc12
Re: Translation of cnc12 Traduction de cnc12
If you mean edit the buttons on the VCP, here’s a link to the manual on how to do this.
No, not at all, I want to redo the translation and add the words that are missing in the software.ShawnM wrote: ↑Tue May 02, 2023 7:06 am If you mean edit the buttons on the VCP, here’s a link to the manual on how to do this.
Non pas du tout je veux refaire la traduction et rajouter les mots qui manque dans le logiciel
All on-screen messages in CNC12 are in the file "language.msg", located in the control software directory (c:\cncm or c:\cnct).
It is a plain text file, which you can edit with any good text editor.
I tried to do it with the windows notepad by copying and pasting the deelp translation but at startup I got an msg language error
J'ai essayé de le faire avec le bloc note de windows en faisant des copier coller de la traduction deelp mais au démarrage j'ai erreur langage msg
windows notepad is not a good text editor, try notepad ++ here.
https://notepad-plus-plus.org/downloads/v8.5.2/
Ok merci je vais voircnckeith wrote: ↑Tue May 02, 2023 1:42 pm windows notepad is not a good text editor, try notepad ++ here.
What format should I choose to save my file
Quelle format je dois choisir pour enregistrer mon dossier
it is a text file, open the file edit it and do not change the extension. keep it as .msg
I made a video for you.
