Communication Errors
Posted: Fri Apr 07, 2023 1:32 pm
I am having communication issues, and have not found the problem.
I have two acorn boards, one on a techno lather the other on a PM-25MV mill, both were working fine before I upgraded to CNC12 4.99 rev 8. After trying to run a part on the mill. I had a communication fault, the fault cleared after moving the RJ-45 connector. It came back and then cleared again. I ran the communication stress test and it failed. I shut down the mill and computer (Intel Nuc with an i5-7260U with a single thread of 1993, Shielded Cable) and restarted it. Failed Communication Stress Test, Moved the connector and it passed the test with No Errors. I figured it was a bad cable and replaced the cable with another shielded cable 3 times (2 from Amazon and one that came with the Acorn board). Still failed.
Tried the Intel Nuc on my lathe and it failed. Swapped the Computer on the Lathe to a Lenovo ThinkCentre M700 (i7-6700T single thread 2078) still failed.
Swapped to the lathe (different Acorn board), Lenovo computer, connected and homed lathe, ran communication stress test, failed test.
Swapped to un-shielded cable and test passed. I will find longer un-shielded cable and try on mill. I have a cable tester coming tomorrow. Any suggestions?
