I started having trouble with my spindle on my Grizzly G9972Z lathe. I'm using a DuraPulse GS20X -22P0 VFD driving a 2hp motor. Occasionally the spindle would not shut off and I would reset the VFD and it would start up again.
Today it did not work (resetting) so I started looking at everything. I decided to un hook the analog input and run the spindle bench test.
Here is what happened...on the very first one I got .87 volts which is less than the 1.65 and it stops the test.
My question is, what else can I check to cause this under-voltage?
Report attached
Centroid Acorn Board
DURAPulseGS20X-22PO
spindle benc htest
spindle benc htest
Re: spindle benc htest
Do you have a capacitor across the 0-10V line?
No, there is no capacitor
I am using a snubber (5.jpg) to stop voltage fluctuating with VFD attached to acorn.
https://centroidcncforum.com/viewtopic. ... 032#p46032
