Inches to metric
- CNC Control System Serial Number: 6844
Inches to metric
How do I change CNC12 from inches to metric?
All my drawings and everything we cut is metric
Re: Inches to metric
Setup / Config / Contrl
Thanks for your reply
Config asks for a password. I type 000, Says Limited access.
Then I can see inches/metric, but not allowed to modify.
I have PRO, License activated.
How do I setup or request the Password?
checked all documentation, no reference to that password
- CNC Control System Serial Number: E062346A1C67-0716214939
Default password is 137
Disable it in the wizard at Preferences/CNC Control, first option top of the page.
Scott
Password worked, I was able to change to mm.
Thanks for your help
be sure to change both "machine units" and "DRO display units" to Millimeters. shut down, reboot, re home out to be safe.ftraube@gmail.com wrote: ↑Tue Mar 28, 2023 12:49 pm Password worked, I was able to change to mm.
Once you get to the configuration screen, you actually change between inch and mm by hitting the spacebar. Change both as Keith said.
Got it. Thanks for the advise
