New Centroid Solid Models of Acorn, AcornSix, Hickory, now available for download.
New Centroid Solid Models of Acorn, AcornSix, Hickory in STEP format (.stp) now available for download.
https://www.centroidcnc.com/centroid_di ... models.zip
ACORN CNC & ETH1616
ACORNSIX & PLCEXP1616
HICKORY CNC
Plasma THC RX and TX
RELAY 8 board
Meanwell power supply
If you don't have a CAD system that will open the .stp format, you can use Autodesk free viewer to look at them.
https://viewer.autodesk.com/designviews
Re: New Centroid Solid Models of Acorn, AcornSix, Hickory, now available for download.
Acorn6 in a too small enclosure :D
Nice models if you are planning the enclosure in 3D
krissondors
Post by krissondors »
Thank you! Perfect timing as I wanted to 3D print some stand offs for my Acorn.
andrkorb
CNC Control System Serial Number: 7804732D0434-050819202, 0008DC111213-0120230049
Post by andrkorb »
it's seems that there no differences between acorn six and Hickory
andrkorb wrote: Mon Mar 27, 2023 5:35 am it's seems that there no differences between acorn six and Hickory
physical size and bolt pattern yes,, every thing else no. :D
