closed loop with Acorn 6 and a linear scale
Now my lathe uses a scale on X for closed loop.
Easy peasy done after work :lol:
Magneto
CNC Control System Serial Number: Not yet delivered
Re: closed loop with Acorn 6 and a linear scale
Post by Magneto »
Quickly becoming a favorite YouTube channel. It's increasingly high level work. Thanks, Uwe.
Black Forest
Post by Black Forest »
Stop making this look so easy! Us mere mortals only can dream of doing this stuff! Great job.
Black Forest
How are you dealing with the conflict between your encoder on the servo and the linear scales? What is the resolution of your encoders? Or is this a non issue?
Black Forest wrote: Sat Mar 18, 2023 2:15 am How are you dealing with the conflict between your encoder on the servo and the linear scales? What is the resolution of your encoders? Or is this a non issue?
I have only tested my default setting.
The x-axis driver is set to 2000 steps/mm, that works fine with the 1000 lines/mm linear scale.
Black Forest wrote: Sat Mar 18, 2023 2:08 am Stop making this look so easy! Us mere mortals only can dream of doing this stuff! Great job.
It looks easy, because the Centroid staff is making things easy peasy for us to use ;)
There are long boring discussions in german forums how to integrate scales in other CNCs, with Centroid it´s a 15min job if you are slow :lol:
midy
Post by midy »
Do you have to have acorn six to use scales?
midy wrote: Mon Mar 20, 2023 4:20 am Do you have to have acorn six to use scales?
Yes with ultimate license, or Oak / AllInOne
Muzzer
Post by Muzzer »
suntravel wrote: Sat Mar 18, 2023 11:15 am There are long boring discussions in german forums how to integrate scales in other CNCs, with Centroid it´s a 15min job if you are slow :lol:
Haha yes, I have closed loop controls on my other (LinuxCNC) lathe. It was "a learning experience" but some features don't work (eg conversational). An OS update will be required to fix that, at which point I'd have to reconfigure all over again, hoping in the meantime that the GUI has also been updated to suit. I may not be able to resolve those issues until I have completed my LinuxCNC PhD ;-)
It makes the "updating to 4.82" challenge look quite trivial.
midy
Post by midy »
Is it not possible to use the encoders on the servos/hybrids to do the same job as using scales?
