Stepper motor upgrade
midy
Post by midy »
I'm going to upgrade my lathe to either servos or hybrid steppers with encoders. Are decent hybrid steppers as good as servos, or is it the case that if you can afford servos then do so? Also I'm in England so anybody here recommend suppliers of steppers and servos?
cheers
Re: Stepper motor upgrade
midy wrote: Wed Mar 15, 2023 2:43 pm I'm going to upgrade my lathe to either servos or hybrid steppers with encoders. Are decent hybrid steppers as good as servos,< no, but they are MUCH better than open loop steppers> or is it the case that if you can afford servos then do so? <yes, Clearpath is a good choice, Leadshine makes affordable servos, Uwe likes the JMC units and has them on his lathe, see his posts and youtube channel>
cheers
krissondors
Post by krissondors »
I have good luck with buying Yaskawa servos and other brands from Alibaba. It's much more affordable than what is offered in the US. What size and kw servo are you interested in?
midy
Post by midy »
Good question, I'm not sure how to match the correct power etc when changing from stepper to servo. I'm currently using 8Nm nema 34 steppers and am still trying to decide on the correct wattage of servo. Just looking online and can't find a source to compare the 2 as far as power goes. I'm sure there will be some sort rule of thumb type thing when swapping the 2? Would definitely want to stick to nema 34 to keep the work to minimum.
with NEMA 34, there are not much options, most servos have a 60 or 80 mm frame in this power range.
Clearpath makes them in this size, Kollmorgen to, but a different price range.
midy
Post by midy »
I'm looking at the JMC's which do a nema 34, they have built on driver, just not sure if they are powerful enough?
https://www.rocketronics.de/shop/de/Ser ... 44-48.html
not sure, I do not use integrated servos, or steppers....
... max torque is under the 220V versions and with power supply they are even more expensive.
