Panel build Centroid Acorn Plasma
Specs:
Centroid Acorn Plasma controller & THC (Black Rx & TX )
Yaskawa Sigma 5 drive paks with 750watt servos (gantry 300lbs)
10:1 reduction
2 enclosures bolted back to back, low voltage panel 24x24x6, high voltage 24x24x10
Nema1 UL approved sourced from Vevor.com
Panel hookup wire 18ga, stranded
Ferrules crimped on all connections.
Heat shrink lables using Panisonic printer
All components drilled and tapped,socket bolted to backplate.
Frame for panels, monitor, pc 1x1x.125 steel tube, steel wheels to prevent slag melt.
Re: Panel build Centroid Acorn Plasma
fantastic! thanks for posting, looks great.
