Direct controlled Pump (Lube Oil Pump For Bridgeport)
- CNC Control System Serial Number: A900325
Docs say these are the best lube pumps to use but I cant find any reference to them on google. I must be using wrong search words. Who makes these and how are they listed? Does bijur make them?
Re: Direct controlled Pump (Lube Oil Pump For Bridgeport)
It is not a particular type of lube pump. Direct controlled just means that the machine's control actually activates the lube pump. Automatic lubrication systems will have a control built into the system that regulates when and for how long to lubricate a system. I am assuming that you are referring to parameter 179 of the Centroid software. The attached tech bulletin should help you.
- 215.pdf
- (78.7 KiB) Downloaded 501 times
lots of lube pumps on ebay.
elrod sells a good one as well.
http://elrodmachine.com/CNC%20Auto%20Lube%20Pump.htm
