i could use some help with this
z,x,c all work in mdi but not y?????
g0 or g1 returns invalid character error..
any help on this new issue would be appreciated?
- CNC Control System Serial Number: 20d77882d94b-0817226462
Re: z,x,c all work in mdi but not y?????
Current 4.99 beta is the only lathe software with working Y, I used B on 4.82
But wait for next Beta with bugfree C-Axis integration for Acorn.
if i sub b in for y in wizard and g code that works?
i tried 499ver3 and lost the db25 signals to y.....tried using header and 24v no joy moved back to 4.82 y works for jog home so i assumed g code worked.
correction jog and home macro work now but no mdi
should also say im using a acorn4
B worked fine with Acorn4, 4th axis in Wizard linear B and MDI should go.
Test 499R4 pls. If there is a bug in DB25 for 4th axis, report and it will be fixed also in R5
And you can use Y
And you can use Y
i moved this thread to the beta software discussion forum.
