Help.
I am replacing all of an AXYZ 4008 electronics with an Acorn By Centroid.
I have all of it running including Automatic squaring.
Running CNC12 V4.99 Rev4 Beta with the hope of better ATC settings.
I am now attempting to set up the 8 tool carousel and :
1) I am running the Stepper motor to turn the Carousel Forward, Stop, Reverse, stop with an Arduino and that is working.
2) I do not have ATC_CarouselForward output (41) and ATC_CarouselReverse output (42) (where do I find them?) Or do I have to make Macros for them
3) Is there a step by stem procedure for this specific Carousel? If not can someone help me with some kind of a roadmap?
4) How do I set tool one to home.
Hi, i see you are running the beta software, so moving this thread to the beta forum.
Re: ATC Carousel
Posted: Mon Feb 20, 2023 5:44 pm
by Angelo DiCenso
Here is a new Link, Hope it works
Re: ATC Carousel
Posted: Tue Feb 21, 2023 6:07 pm
ok! that helps alot. now we can see what you got.
Re: ATC Carousel
Posted: Tue Feb 21, 2023 6:25 pm
two ways to go.
1.) install the release version of CNC12 Mill v4.82 and follow the ATC carousel instructions here. (and install your Pro or Ultimate License, report shows system is still on "Free") https://www.centroidcnc.com/centroid_di ... ograms.zip
2.) or continue to work with beta software and use the new built-in ATC menu in the Wizard to setup the Carousel.
i should have an updated v4.99 rev5 public beta very soon.
cnckeith ;
I have uploaded 2 more photos that show the pro license installed, I don't know why the report shows otherwise.
I have gone through many pages of instructions (including the your link) and it's just getting worse.
1) I should first get the carousel to home, to tool (1), Totally disregard the ATC_CarouselForward and ATC_CarouselReverse.
now that you have seen the photos what is a good approach for that?
Am I going in the right direction?
Re: ATC Carousel
Posted: Tue Feb 21, 2023 9:15 pm
by Angelo DiCenso
cncKeith;
Could the license glitch be eliminating the ATC_CarouselForward and ATC_CarouselReverse from my OUTPUT list??
Re: ATC Carousel
Posted: Wed Feb 22, 2023 1:45 pm
Angelo DiCenso wrote: ↑Tue Feb 21, 2023 7:12 pm
cnckeith ;
please post a fresh report.zip, maybe the report you posted was before you installed the license.
