CNC on the cheap. Kai's Techno Router Acorn CNC controller build part list
Posted: Thu Feb 16, 2023 9:23 pm
Kai's Techno Router Acorn CNC controller build part list. CNC on the cheap.
Leadshine Closed loop stepper motors and drives.
2x CS-M22323-S
1x CS-M22323B
3x CS-D508
3x 3 meter long cables
Brake motor on Z
Motor drive power supply
USB communication cable for communicating with drive
Amazon links to parts used in this build.
updated links with Stepper Online axis motors and drives! 3-20-25
Closed Loop axis motors and drives.
https://amzn.to/4kFtz7B
power supply.
https://amzn.to/4ijG735
Electrical Box
https://amzn.to/3IvBT8P
CNC PC
https://amzn.to/3IuvSZZ
Touch Screen
https://amzn.to/3kl1GY6
Din rail terminal blocks
https://amzn.to/3YZIBtl
Din rail.
https://amzn.to/3xuijU5
Wire Markers
https://amzn.to/3k02zp0
Quick Docking wire connectors
https://amzn.to/3XHZdV7
Din rail terminal block quick connect.
https://amzn.to/3xtgBm1
Dial indicator with mag base.
https://amzn.to/3I6TsLc
Lever nuts connectors.
https://amzn.to/3Ecl00g
more lever nut connectors.
https://amzn.to/3XHL62e
120mm x 25 mm cooling fan
https://amzn.to/3XCiBmw
Electrical box main power rotary switch
https://amzn.to/3S56eyc
6A circuit breakers.
https://amzn.to/3YDAtyC
Push button estop.
https://amzn.to/3I72DLt
DB25 flying lead for easy drive connections.
https://amzn.to/3IaGEDm
Shielded signal cables 22 gauge. two conductor with ground
https://amzn.to/3xpNIY1
Din rail 24 vdc power supply 1 amp
https://amzn.to/3EauXeM
Din rail 24 vdc power supply 3 amp
https://amzn.to/3k1KDKB
Stepper motor to ballscrew coupler
https://amzn.to/3Eghimt
Physical Cycle Start, Feed Hold, Tool Check and estop
https://amzn.to/3YEojWv
Wire track for Z axis cables on gantry.
https://amzn.to/3lJabN7
Fan dust filters
https://amzn.to/3xthUkV
3 foot shielded ethernet cable.
https://amzn.to/3YJllQE
Wire.
https://amzn.to/4103DtB
Wire stripper.
https://amzn.to/3S3PPKy
Small wire stripper. for those tiny db25 wires!
https://amzn.to/3Kb8mmf
alternative.
https://amzn.to/3Id8Cyt
Basic wire stripper
https://amzn.to/3IfrWLt
More gear we use but don't sell is here.
2x CS-M22323-S
1x CS-M22323B
3x CS-D508
Brake motor on Z
power supply.
Electrical Box
CNC PC
Touch Screen
Din rail.
Wire Markers
Push button estop.
Fan dust filters
Wire.
Wire stripper.
alternative.
Basic wire stripper
