Retro a Sharp 6-18 NC OD grinder with Acorn Control. OEM NControl irratic, failing. Sharp no longer supporting; they said buy a new machine $80K, not happening.
Kept most electronical as can see in picts, replaced controller with Acorn, and Mitsubishi drive and motor to Yaskawa Sigma V. Used most of front panel hard switches and indicator lights. Modified PLC for safety interlocks to shutdown and retract in the event of loss of spindle, wheel or coolant; saves wheel and part. Wrote macros for grinding apps: reciprocation and plunge grinding. Now more versital for customer cause can customize operation for production, or special jobs.
Just went in to operation and already discussing upgrades: change recip axis to servo for precise positioning; automatic wheel dressing and w offset comp. more to come.
Fully documented retro step by step, schematics, ladder logic; ready for the next one.
Get a nice seal LCD and keyboard and it will look great.
Acorn For OD Grinder
- CNC Control System Serial Number: ok375 - C120629; ok375 - c120683
Re: Acorn For OD Grinder
for CNCkeith,
How to enable wireless MPG. Ordered it at same time as Acorn Controller, and Addon 1616 board. assumed it work would work out of the box, just plug it in. Not so. is an unlock or license key required.
BS
BS
The Pro License is required for Wireless MPG use. The Pro License also provides many other features, such as unlimited file size, etc.
- CNC Control System Serial Number: 0035FF98BF3B-0325225816
Excellent job! On a scale of 1-10, what would you rate the difficulty?acorn_automation wrote: ↑Thu Feb 16, 2023 12:03 pm Retro a Sharp 6-18 NC OD grinder with Acorn Control.
What did you know about Acorn before starting this task?
How long did it take?
I'm thinking about buying a older mill and upgrading it.
acorn_automation,
Hello.
WMPG setup instructions should come with it, and they are also online here.
https://www.centroidcnc.com/centroid_di ... ss_mpg.pdf
cool build! looking forward to video!
Hello.
