ShaAli
Posts: 41 Joined: Mon Nov 21, 2022 12:51 pm
Post
by ShaAli » Sat Feb 11, 2023 3:13 pm
Hello,
Would it possible to help me figure out how do I connect (wire) some 110v devices like shopvac, air compressor using this relay? I tried to search for the wiring diagram and I was not able to find. I am it exists
Thank you so much for all your help.
Gary Campbell
Posts: 2353 Joined: Sat Nov 18, 2017 2:32 pm
Post
by Gary Campbell » Sun Feb 12, 2023 5:03 pm
Those devices draw too much current to be connected directly to the acorn relay board and should be controlled by a contactor
Posts: 2977 Joined: Fri May 24, 2019 8:34 am
Post
by ShawnM » Sun Feb 12, 2023 9:16 pm
And that contactor Gary mentioned is then controlled by one of the 8 Acorn relays.
ShawnM on Mon Feb 13, 2023 8:30 am, edited 1 time in total.
TheKitMill
Posts: 153 Joined: Wed Sep 06, 2017 1:52 pm
Post
by TheKitMill » Sun Feb 12, 2023 11:45 pm
Something like this will control the things you want to turn on and off like shop vac etc
Gary Campbell
Post
by Gary Campbell » Mon Feb 13, 2023 9:31 am
If you do use an SSR, make sure that you use one designed to match your load type. AC Inductive, resistive and capacitive loads are each best served by slightly different specs. And use 2 (or a double pole) if switching 230VAC. Also, since many DIY guys buy on price, after wiring is complete, make sure that the load terminals go to zero volts when off, not all of them will.
ShaAli
Post
by ShaAli » Mon Feb 13, 2023 8:02 pm
Thank you all for your valuable information. I appreciate it very much
