Adding a 4th axis to my router
bob.berner
Post by bob.berner »
Hi, I"m researching adding a rotary axis to my Acorn CNC router. I have used a Rotary a ew years ago on a Legacy Maverick using conversational cam for the programing. Is it a similar process in the Acorn universe? Can anyone give me some advice or point me in the right direction?
Re: Adding a 4th axis to my router
With conversational Intercon you can only index the 4th axis.
For complex 4 axis programming I would use an CAM system like fusion 360.
Not entirely true: you can include the rotary fourth axis in interpolated (Linear) moves as well, but you have to calculate the appropriate combined linear+angular feedrate yourself. See http://www.cncsnw.com/4thHowTo.htm
But as Uwe says, for anything more complex that a few lines or a spiral cut, you will definitely want a CAD/CAM system to do the computations for you.
Gary Campbell
Post by Gary Campbell »
bob.berner wrote: Sun Feb 05, 2023 10:37 am Hi, I"m researching adding a rotary axis to my Acorn CNC router. I have used a Rotary a ew years ago on a Legacy Maverick using conversational cam for the programing. Is it a similar process in the Acorn universe? Can anyone give me some advice or point me in the right direction?
Bob...
If you are a Vectric user you can surely replicate everything that legacy's concam and much more with Vectrics VCPro or Aspire by entering positions, lengths and/or angles into the calculating input boxes.
I used to teach the method at seminars, but it seems users were more receptive to the cad methods so I quit in '18
bob.berner
Thanks guys,
The project I am considering is indeed very simple, basically a long taper on both ends of a long dowel. I just need to make hundreds of them. What do I need to buy for the 4 axis mechanism? Is it difficult to install? I am assuming a head stock and tail stock, a motor and motor controller. Is there a turnkey package out there? I know Avid CNC has one but don't know about the compatibility with Acorn since they use Mach3.
bob.berner wrote: Thu Mar 23, 2023 11:44 am Thanks guys,
the avid one will work with Acorn.
