x-x+ jogging moves in the same direction in the x- direction <resovled>
Re: x-x+ jogging moves in the same direction in the x- direction
Check the DIR signal output from Acorn as I suggested. If it is going high and low, then Acorn is OKmccue.sc wrote: ↑Wed Jan 25, 2023 7:31 am no changes was sitting for about a month before I could find the time to put on the mill was making a bulkhead for cables to pass thru the bottom of the cabinet. powered back up with the cables just thru the hole in the bottom power supply for the motors and ethernet cable for the acorn turned back on and x was acting up but will try and post video later tonight. attached the schematic that i followed and used the optional drive ok signal in blue on schematic.
You have a REVISION 3 hardware board?
Keith, any reason he shouldn't be using this schematic instead?: https://www.centroidcnc.com/dealersuppo ... 972.r6.pdf
A thought:
After you startup the control and reset it, but BEFORE you press Cycle Start to home the machine, can you jog each axis in the positive and negative direction?
Who is "they" and WHEN did you order it.
That is an early board designed in 2017.
rev3 Acorn board works just fine!martyscncgarage wrote: ↑Wed Jan 25, 2023 1:27 pmWho is "they" and WHEN did you order it.
I would rather see you using the modern hardware.
post screen shots of the Clearpath setup software.
review
https://centroidcncforum.com/viewtopic.php?f=60&t=5531
y+ goes to high 23 volts y- goes low .02 volts x+ or minus. goes low 0 volts
Did you disconnect the wires to the Clearpath motors?
Z axis?
When and where did you get your Acorn board?
z goes high & low
