DELTA ASDA A2 servos
Posted: Sun Jan 08, 2023 4:47 pm
Hi guys ,
I have problem with delta servos and Alarm (. AL020 )
I did set all parameters as it is in manual - https://www.centroidcnc.com/dealersuppo ... ds/303.pdf
but this AL020 is popping up and stopping centroid with message DRIVE FAULT...
It is strange as motor turns when jogging for about a second when servo is not enabled, soonest as i enable servo it wont turn and DRIVE FAULT message pops up right a way.
Also when i tuned motors, motors were turning and tuning just fine both directions .
In Delta user manual it says, that this AL020 alarm is ( Serial Communication Time Out ) but we are not using RS-232 communication port.
I did check all cables and connectors and they are good, i did hook up another servo 1kW and same Alarm ... What am i missing ?
How can i bypass this alarm ?
Thank you
Thank you
