Hi,
My 4th axis is a rotary named a. However when the machine homes it goes thru xyz without issue but shows a w and an error where an a should be…How can this be changed to match the a.? Hope this makes some sense.
Renaming and axis <answered>
- CNC Control System Serial Number: A901150
Re: Renaming and axis
Edit the file named "cncm.hom" in the c:\cncm directory. Change the 'W' to 'A' wherever it appears.
Thank you . I believe that solved it.
