Cutting different depths with the same profile plane
tkoon-imc
Post by tkoon-imc »
Good afternoon,
I am posting to see if anyone has experience changing the depth of cut with retaining the same path. My company specialized in lathe turning and we often have to return our products that have been sent back to meet specs after usage. However, each product will have different wear so a single CNC program would not work. I have thought about simply changing the tool offset but did not want to go that route. Thank you!
Re: Cutting different depths with the same profile plane
hi, i moved this post to the Machining Strategies forum.
Can you show a drawing? I am not really catching what you want to achieve.
You could use G52 to temporarily shift the work coordinate system.
If it is a one-tool job, I would just do it with the tool offsets (preferably the wear offsets, so it is easier to reset).
; Description: Offset X from User
; Programmer: Uwe
; Date: 20-Dec-2022
; --- Header ---
N0001 G21 ; millimeter measurements
  :::: --- Stock Dimensions ---
  :::: X- = -20.0, X+ = 20.0
  :::: Z- = -60.0, Z+ = 0.0
  G40 ; Cutter Comp Off
  G28
M224 #101" Type Diameter Offset %f\n Cycle Start to continue"#101
; --- Rapid ---
N0002 T0100
  M9
  G96 S120.0 M3
  G4 P1.0
  G0 X[10.0+#101] Z0.5 T0101
N0003 G1 X[12.0+#101] Z-0.5 G99 F0.1
N0004 X[12.0+#101] Z-10.0
N0005 X[28.0+#101] Z-10.0
N0006 X[30.0+#101] Z-11.0
N0007 X[30.0+#101] Z-20.0
N0008 X[36.0+#101] Z-30.0
N0009 X[40.0+#101] Z-30.0
N0010 G28 T0100
  M5
  M9
  G40
; End of Program
Diameter Offset from Operator input, but needs some editing of all X values in the G-Code.
