Lathe part zero <answered>
Posted: Sun Dec 18, 2022 12:38 am
by Tcwms
I am having issues with setting part zero and just trying to eliminate all possibilities. Sometimes X0Z0 is correct and sometimes X0 travels to the -X side of the part. When loading a lathe program created other than in Intercon (Fusion 360 in this case) is the part zero set before the program is loaded or after? Or does it matter? Similarly, do you set part zero before creating an Intercon program or after, but before posting it?
Re: Lathe part zero
Posted: Sun Dec 18, 2022 12:52 am
by suntravel
Set part O before graphing is ok.
Re: Lathe part zero
Posted: Sun Dec 18, 2022 1:43 am
by cncsnw
You can set part zero at almost any point in the process.
I recommend doing it as you are getting ready to run the job: after writing it, after loading it, after setting tool offsets, but before graphing it (because the F8/Graph screen will tell you whether or not running the job, with your current part zero, will stay within your software travel limits.
Re: Lathe part zero
Posted: Sun Dec 18, 2022 9:05 am
by tblough
Make sure you have set the correct nose vector for your tool in the tool table.
Re: Lathe part zero
Posted: Sun Dec 18, 2022 2:27 pm
by Tcwms
Thanks to all of you for your responses. I didn't think it mattered to set before or after the program was loaded, but needed some confirmation.
