RoxanaPS
- CNC Control System Serial Number: E0623464B717-0628226384
Post
by RoxanaPS »
Trying to figure out what is causing this.
https://youtube.com/shorts/Z21jN1f16ws?feature=share
Post
by suntravel »
Looks like a mechanical issue. How do you drive the axis?
RoxanaPS
Post
by RoxanaPS »
Closed loop rack and pinion.
RoxanaPS
Post
by RoxanaPS »
It only does it when the gcode count is large. It takes about 7-10 minutes to start happening.
CNCMaryland
Post
by CNCMaryland »
Are you using an ethernet port on the computer that is running the software?
RoxanaPS
Post
by RoxanaPS »
Yes.
CNCMaryland
Post
by CNCMaryland »
You really need to post a report. Could be the computer not being able to process the lines fast enough, or you could have communication issues.
RoxanaPS
Post
by RoxanaPS »
Where do I post it?
CNCMaryland
Post
by CNCMaryland »
Right here, attached the zip file, then other members can download and review it for issues.
RoxanaPS
Post
by RoxanaPS »
The date IS off but this is from today.
- report_E0623464B717-0628226384_2022-11-15_12-54-22.zip
- (1.04 MiB) Downloaded 6 times
