CNC11- Any way to put up Graph when part cutting?
countryguy
Post by countryguy »
Rather than watching the G-code during g-code program execution, is there a way to have CNC 11 put up the part being cut similar to that 'other' stepper based product that shall remain nameless :D
Re: CNC11- Any way to put up Graph when part cutting?
yep... its called Run Time Graphics. in the "Run" menu select RTG to turn it on.. now when you press cycle start you'll see the graphics while you are running a job. you can also switch back and forth from graphics to g code on the fly.
be sure to have your tool diameters set properly for best viewing while cutting.
