Program error , settings, or software glitch
Posted: Mon Oct 31, 2022 8:23 am
by cad cam man
X AXIS BEARING MOUNT REV_4_ MOTOR SIDE_1st op_review.txt
G code file
(759.73 KiB) Downloaded 13 times
I was running my mill this weekend doing some dynamic milling . Im running cnc12 4.8 , I used mastercam 2018 to program the part with . This is what happen , as I was roughing the outside shape after making it half way thru the program the machine kept cutting at the set up speed ...meaning when it is finished with a cut it uses higher feed rates to reposition itself to start a new cut , the cutting feed rate was 6.5 and the reposition feed was 100, so when the machine didn't slow down to the cutting feed rate the cutter overloaded itself and shut down. My deal is I can't find anything that stands out to me maybe I have been looking at it too long and some fresh eyes can help me , I'm not sure if it is a program error or if the software " glitched" im not sure I would think its a program error so can some take a look and see if something does look right. I will attach the report file later this evening but for now I have attached the g code file
Re: Program error , settings, or software glitch
Posted: Mon Oct 31, 2022 2:30 pm
please post a fresh report.zip so we can see the cnc control settings and error log of the machine tool
Posted: Mon Oct 31, 2022 3:39 pm
i took a look at the posted g code.. i see the feedrate changing from F6.42 to F100
looks like to me CNC12 is doing exactly what its being told to do so i'd go back to MasterCam and review the selections and settings.
when the 'tool overloaded" did you stop CNC12? if so, go in the Run menu and click "search" it will display the line number that the g code program was interrupted on.. this is useful info.. now open the g code program in Notepad ++ and start studying the g code in that area. you will find the issue.
N32092 G3 X2.3684 Y-.5863 I.0195 J.1108 F100.
N32093 G1 X2.3731 Y-.582
N32094 G3 X2.3868 Y-.4309 I-.0759 J.0831
N32095 G1 X2.3686 Y-.412 Z-1.6917 F6.42
N32096 X2.3467 Y-.3979 Z-1.6933
N32097 X2.322 Y-.3892 Z-1.695
N32098 X2.2961 Y-.3865 Z-1.6967
N32099 X2.2701 Y-.3897 Z-1.6983
N32100 X2.2457 Y-.3989 Z-1.7
N32101 G2 X2.2172 Y-.4116 I-.1282 J.2489
N32102 X2.213 Y-.4132 I-.0997 J.2616
N32103 G3 X2.1954 Y-.4241 I.017 J-.047
N32104 X2.1838 Y-.4412 I.0346 J-.0361
N32105 X2.18 Y-.4602 I.0462 J-.019
N32106 G1 Y-.481
N32107 X2.1824 Y-.5042 Z-1.698
N32108 X2.1895 Y-.5263 Z-1.696
N32109 X2.2181 Y-.5913 Z-1.69
N32110 G0 Z.25
N32111 X-.025 Y2.625 Z2.
N32112 Z.2
N32113 G1 Z-.85
N32114 G41 D4 Y2.125
N32115 G3 X0. Y2.1 I.025 J0.
N32116 G1 X1.4674
N32117 G2 X1.9185 Y1.8157 I0. J-.5
N32118 G1 X2.3186 Y.979
N32119 G2 X2.3675 Y.7633 I-.4511 J-.2157
N32120 G1 Y-.15
N32121 G2 X2.15 Y-.3979 I-.25 J0.
N32122 G1 Y-1.6
N32123 G2 X1.65 Y-2.1 I-.5 J0.
N32124 G1 X.75
N32125 G2 X.5 Y-1.85 I0. J.25
N32126 G1 Y-.42
N32127 X.5381 Y-.3591
N32128 G3 X-.5381 I-.5381 J.3371
N32129 G1 X-.5 Y-.42
N32130 Y-1.85
N32131 G2 X-.75 Y-2.1 I-.25 J0.
N32132 G1 X-1.65
N32133 G2 X-2.15 Y-1.6 I0. J.5
N32134 G1 Y-.3979
N32135 G2 X-2.3675 Y-.15 I.0325 J.2479
N32136 G1 Y.7633
N32137 G2 X-2.3186 Y.979 I.5 J0.
N32138 G1 X-1.9185 Y1.8157
N32139 G2 X-1.4674 Y2.1 I.4511 J-.2157
N32140 G1 X0.
N32141 G3 X.025 Y2.125 I0. J.025
N32142 G1 G40 Y2.625
N32143 G0 Z.25
N32144 X-.025
N32145 Z-.65
N32146 G1 Z-1.7
N32147 G41 D4 Y2.125
N32148 G3 X0. Y2.1 I.025 J0.
N32149 G1 X1.4674
N32150 G2 X1.9185 Y1.8157 I0. J-.5
N32151 G1 X2.3186 Y.979
N32152 G2 X2.3675 Y.7633 I-.4511 J-.2157
N32153 G1 Y-.15
N32154 G2 X2.15 Y-.3979 I-.25 J0.
N32155 G1 Y-1.6
N32156 G2 X1.65 Y-2.1 I-.5 J0.
N32157 G1 X.75
N32158 G2 X.5 Y-1.85 I0. J.25
N32159 G1 Y-.42
N32160 X.5381 Y-.3591
N32161 G3 X-.5381 I-.5381 J.3371
N32162 G1 X-.5 Y-.42
N32163 Y-1.85
N32164 G2 X-.75 Y-2.1 I-.25 J0.
N32165 G1 X-1.65
N32166 G2 X-2.15 Y-1.6 I0. J.5
N32167 G1 Y-.3979
N32168 G2 X-2.3675 Y-.15 I.0325 J.2479
N32169 G1 Y.7633
N32170 G2 X-2.3186 Y.979 I.5 J0.
N32171 G1 X-1.9185 Y1.8157
N32172 G2 X-1.4674 Y2.1 I.4511 J-.2157
N32173 G1 X0.
N32174 G3 X.025 Y2.125 I0. J.025
Posted: Mon Oct 31, 2022 4:24 pm
by suntravel
Jep, same as Keith, the g-code is not ok.
You have lots of cutting with F100
Posted: Mon Oct 31, 2022 6:45 pm
by cad cam man
Thanks for taking the time to review the file it does look like it is cutting but these are positioning moves . I have the line it stopped on , but I am taking everyone's advice and going back to mastercam to look it over .....I am going to rerun the program above the material " air cut " and see if I can catch it doing it again . I'm thinking I had the rapid over ride on . I did have the feed override on at 200% but that was at the beginning of the program , The error occurred around 13,000 so ill see if it will do it again under the same conditions . I will also post the report file when I get to the shop
