SEM servo motor with allin1
converterking
Post by converterking »
Would this dc servo motor work with an allin1 control?
SEM MT40W4-90
C.STALL TORQUE 75LB/IN 10.5 A
MAX 2000 RPM 180 V 65 A
Centroid_Liviu
Re: SEM servo motor with allin1
Post by Centroid_Liviu »
It would most likely run reasonably well with the ALLIN1DC. However we recommend using an AC/DC for maximum performance.
converterking
What do you mean by reasonably well?
Centroid_Liviu
The peak torque you could achieve would be less than what it would be with using the AC/DC.
ALLIN1DC: 75 in/lb continuous, 127.5 in/lb peak
AC/DC-30: 75 in/lb continuous, 150 in/lb peak at recommended setting (peak current = 2 times continuous)
