Speed Reduction Angle Head
Posted: Sun Oct 09, 2022 9:32 pm
HI Everyone,
I'm building a Right Angle head for my mill to, basically, use it as a horizontal borer. However, due to my mill being 1:1 (motor:spindle) and I often do larger bores, I'm gearing down the angle head 2:1 as I'm usually boring at 60-150 RPM. My Main question is, and I know there's a couple of people on here that will know the answer but I thought I'd leave it open, can I use a gear selection in in the software to trick the system into thinking I'm in low gear (and Reverse) when I attached the Angle head?
The main concerns for wanting to do this are:
1. Rigid Tapping (although I am aware I can just use a different Speed and Q value, and use G74 instead of G84)
2. Tool retraction during G76 Boring Cycle (although I am aware this is a luxury and not specifically required)
3. Correct feed rates in conjunction with the feed override knob etc.
4. Reduced likelihood of error in the above examples, and when drilling, boring, milling, etc. (I will be far less likely to make an error if I can just tell it to use low gear, and program normally, as opposed to calculating everything every time with different speeds and feeds (an spindle direction)..
I guess the next part of the question is: If the encoder in on the motor (which it is) and I have a 2:1 reduction in the angle head, when I do an M19, will it still randomly stop at either point 180 degrees apart, or is there a way to get it to stop in the same position each time. This will be mostly important for tool retract in g76 cycle, but I imagine will be equally as important with tapping cycles If I needed to go back into the hole for any reason.
Feel free to tell me I'm an idiot.
Thanks in Advance.
Jason
Thanks in Advance.
Jason
