I’m looking for a probe to measure tool offsets on my lathe.
I’ve seen a couple on here in the past. Searched for quite a while and never found anything of course.
I appreciate any links of guidance. Thank you I’m advance!
Lathe tool probe
Re: Lathe tool probe
I suggest reaching out to user suntravel, I remember reading a post about his probe
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
Centroid's TT-2 works remarkably well - https://www.centroidcnc.com/cnc_tool_set.html
specify for lathe when ordering in the notes section on checkout
https://www.centroidcnc.com/centroid_di ... choff.html
Oh! Wow! Can you elaborate on how this works? I can't find anything about this probe on a lathe.cnckeith wrote: ↑Mon Oct 03, 2022 4:33 pm specify for lathe when ordering in the notes section on checkout
Also, how do I order the bulkhead cable for inside the control cabinet? I like that setup better and I'm happy to pay for it.
Also, can it be easily converted from lathe to mill and back?
email diysales@centroidcnc.com they will help you with your order.slodat wrote: ↑Mon Oct 03, 2022 4:35 pmOh! Wow! Can you elaborate on how this works? I can't find anything about this probe on a lathe.cnckeith wrote: ↑Mon Oct 03, 2022 4:33 pm specify for lathe when ordering in the notes section on checkout
Email sent!
I'm sure others are interested in the answers to the question about using on lathe and mill. I know I am!
Look at the TT-2 brochure - it shows the probe mounted in a lathe with the lathe anvil mounted. KP-3 is similar. Lathe and mill applications only differ in the "end effector". Lathe gets a circular anvil; mill gets a ball tip.
