Slave axis getting unpaired <install pro license file>
johannes
Post by johannes »
The slaved Axis keep getting unpaired.
I have slaved Axis 4 to Axis 2 in the Wizard.
I can confirm in the VCP, and I also verify that both motors are moving as expected.
02 - Confirm Axes paired.png (8.59 KiB) Viewed 919 times
Then, if I click "Set WCS XY0", the axis are unpaired.
05 - Setting WCS XY0 unpairs axes.png (14.25 KiB) Viewed 919 times
No matter how many times I click on "Re-pair Axes", it is not able to. Even if the message says succesful.
And back in the wizard, sure enough, the axis are still unpaired.
Acorn also shows the slaved axis is no longer enabled.
The motors are Clearpath motors, powered by an IPC5, via the POWER4HUB board.
The motor signals are wired through a https://www.cnc4pc.com/c86accp-clearpa ... oller.html board
I have X on 1, Yleft on 2, Z on 3, and Yright on 4.
I dont understand why it keeps losing axis pairing - is there something obvious I'm doing wrong?
See attached report files
Sword
Re: Slave axis getting unpaired
Post by Sword »
Do you have a CNC12 Pro license applied? A pro license is required for paired axis configurations.
Scott
johannes
Post by johannes »
Sword wrote: Fri Sep 16, 2022 11:25 am Do you have a CNC12 Pro license applied? A pro license is required for paired axis configurations.
Ah crap, I forgot to reimport the license after I had to reinstall CNC12. Of course..
Sword
Post by Sword »
BTDT :oops: ;)
Scott
