Darn - Forgot to ask 1 other question- The 3 Encoder wire jackets includes a shield wire w/ foil wrap Do you usually put the Shield of the cable to power GND or chassis ground? TIA.
Jeff.
DC-AIO and cable shields. To Machine chassis ground?
Re: DC-AIO and cable shields. To Machine chassis ground?
Solder the shields to the outer shell of the DE9 connectors. That will connect them to chassis ground.
Thank you very much for the speedy reply's here and on CNCZone! You guy's are awesome!
CG.
CG.
