Connect a Lichuan LCDA357H driver to Acorn CNC
Hugo Turn
CNC Control System Serial Number: E06234797992-0615226285
Post by Hugo Turn »
I am going to use Lichuan LCDA357H closed-loop drivers for a retrofitted lathe with Acorn CNC.
What is the recommended method to connect the drivers?
Acorn header connections or the Acorn DB25?
I attach a .pdf with the characteristics of the diver.
LCDA357H-b.pdf
(265.25 KiB) Downloaded 30 times
Hugo González
Re: Connect a Lichuan LCDA357H driver to Acorn CNC
5V logic should be connected to DB25
Hugo Turn
Post by Hugo Turn »
Is it a connection scheme similar to the one attached (although this is for another driver)?
KL-5056 drivers15129.r1.pdf
(165.15 KiB) Downloaded 25 times
Hugo Gonzalez
ZZBOB
CNC Control System Serial Number: 20915A (1124081904)
Post by ZZBOB »
HI THERE..
Do a search for..NEED HELP with this DRIVER...(1/20/20)
ZZBOB...
Hi Hugo, yes, it's similar to the diagram you posted. Start with the PUL and DIR connections only. You may not need the ENA line connected as the drive may be enabled by default. Start with ONE drive wired to the DB25 and get that ONE working. Then add a second and get that one working. Wire one at a time to be sure each one works on its own.
You can wire up the alarm signal later if you wish. I'd set the "Pulse/Rev" dip switches to 1600 or 3200 to get it working.
skipper616
Post by skipper616 »
I have the LCDA357H connected to the header (not the DB25) and works fine. This is on a very early Acorn board so not sure if later boards have a limitation.
Hugo Turn
Post by Hugo Turn »
It would be interesting to know what are the advantages or disadvantages of connecting this driver to the headers (differential output) or to the DB25 (5V TTL)
