Centroid is releasing the second revision of the Plasma THC RX and TX boards
Posted: Wed Aug 03, 2022 12:13 pm
Hello Acorn Plasma users!
We are happy to announce that Centroid is releasing the second revision of the Plasma THC RX and TX boards.
The new boards are easily identified by the color change from green to black.
The new Black RX and TX boards have all the great features of the rev 1 green boards with the addition of more inputs on the TX board.
The new inputs on the TX board are intended for plasma specific use. Torch Breakaway/Collision and Torch Float switch. With the Black TX board these signal can now be sent over the fiber optic isolation cable to the RX board for further optical isolation protection for the Acorn inputs. In addition to the added inputs the Black TX board has new circuitry for the “T IN” input (Ohmic/Conductive) which eliminates the need to run t he Torch Tip conductor through a relay simplifying the wiring and configuration of the THC kit.
Here is a link to a Acorn Black TX/RX typical 3 sensor Round Mount wiring diagram.
https://www.centroidcnc.com/dealersuppo ... 136.r2.pdf
The new Black TX and RX boards do not require any software updates and are compatible with all Acorn Plasma software versions and Licenses.
Future Replacement Parts for Green RX/TX board owners: Black TX boards are compatible with Green RX boards so any future replacements for Green TX boards will be Black. In this special case the Black TX board’s additional inputs are not used so there will be no wiring changes when replacing a Green TX board with a Black TX board.
I will be updating the Centroid Plasma web page and installation manual with the Black RX and TX board images and information over the next few days. Happy cutting. -Keith
