Hoping someone has mercy on me!
I am starting to retrofit an Emco Concept Mill 55 with a Centroid Acorn in my classroom. I am a teacher and by no means an expert at this sort of thing. I think I have most of the info I need, but am unsure how to properly wire the original Lenze VFD. Would anyone happen to have any schematics that show how to wire the VFD to the Centroid Acorn? The VFD is the Lenze e823v751. Here is a link: https://download.lenze.com/TD/E82EV__82 ... -0__EN.pdf. I think page 194 gives the necessary info. The inputs/ outputs currently used by the original ACC system are: 62, 7, 8, 28, E1, E4, 39, A1 and 59. I know where some of these would connect, but am unsure of others. Please let me know if you need additional info.
Thank you in advance!
Jerry
Emco Concept Mill 55 w/ Lenze VFD
Re: Emco Concept Mill 55 w/ Lenze VFD
Jerry,
Hello.
It looks like this connection configuration should work. Wiring and Wizard i/o settings PDF attached.
Hello.
- Lenze_VFD-DRAFT.pdf
- (144.55 KiB) Downloaded 36 times
Hello!
You have just made my day! THANK YOU! I can't wait to use what you sent me and hook everything up when I return to school in two weeks! It (almost) makes me excited to return .
Thanks again!
Jerry
Thanks again!
Jerry
How did you hookup the individual drives? Curious if you have photos of the box and layout! Thanks so much.
not a mill but emco lathe start to finish.Allthewatts wrote: ↑Mon Apr 15, 2024 10:28 pm How did you hookup the individual drives? Curious if you have photos of the box and layout! Thanks so much.
https://centroidcncforum.com/viewtopic. ... 4&start=10
