Probe AND HomeAll to one input, possible?
Spartan117
Post by Spartan117 »
Hello,
i would like to know if it is possible to use one Input on the Acorn for two signals?
I thought about using probe and HomeAll on one input.
But LimitAll and HomeAll could also be a candidate for that on a mill.
The wizard seems to accept only one signal per input.
After a look at a "standard lathe plc" first it seemed to be easy:
acorn_lathe_plc.src:
;                        INPUT DEFINITIONS
;               Closed = 1 (green)  Open = 0 (red)
Unused1                       IS INP1 ;&*;
Unused2                       IS INP2 ;&*;
Unused3                       IS INP3 ;&*;
Unused4                       IS INP4 ;&*;
Unused5                       IS INP5 ;&*;
Unused6                       IS INP6 ;&*;
Unused7                       IS INP7 ;&*;
EStopOk                       IS INP8 ;&*;
; #endregion
I thought, i will just have to change it like that:
;                        INPUT DEFINITIONS
HomeAll                       IS INP1 ;&*;
ProbeTripped                  IS INP1 ;&*;
; #endregion
But it didn't work, i got lots of error-messages when compiling.
So before i start fiddling around for days now^^, i wanted to ask you guys first:
Is it possible to assign two different signals to the same input in the plc?
I have some ideas how to setup the "real" separation of the signals by hardware, but can someone tell me, if the PLC supports that "doubling" at all?
I know, easiest and best way would be to buy an Ether1616, but the hobby budget doesn't stretch that far in the near future :oops:
Thank you very much and with best regards,
Marc
German-speaking, so please be patient with my english-skills :)
Re: Probe AND HomeAll to one input, possible?
post a fresh report.zip so we can see the input assignments
Spartan117
OK, i will try to get that in the right order, because i already tried some more and did some more testings.
First, I made a report like it was with all that modifications.
BUT keep in mind, i was really fiddling around in there, just testing by out-commenting the lines that threw an error when compiling, but without knowing what that really does. I just wanted to test the behaviour when assignig two signals to the same input, just for experimenting, no matter what other things could be affected for now.
I attached that report, but keep in mind, i wouldn't use such an unprofessional, noob-edited-src really, later ;-) )
THEN:
I just compiled a new, unmodified acorn_lathe_plc.src and there i only added the lines for the inputs from above (Probe=Inp6, HomeAll=Inp6), to be able to tell you the exact error-messages that the compiling threw out with them. This is the picture i attached.
But that means, the .src/.plc of the report doesn't exist anymore now, please keep that in mind. I want to start with a fresh .src without that uncommented lines, when i know if and how that 2 signals-1 input-thing works.
As i am asking for a general behaviour and not something regarding one special .plc i hope this doesn't cause too much of a problem now?
I will have to use a turret-lathe-plc for my emcoturn120 later, anyway.
But i thought, start low, go slow at first ;-)
report_80F5B5B922D4-0211225687_2022-06-29_21-36-24.zip
(627.49 KiB) Downloaded 26 times
Both *.src from the report are compiling without errors....
Spartan117
As I said, there I just did outcomment all lines that threw an error. But that's not a good solution I'd say ;)
The errors occur with a fresh src that only has got that input-entries I posted above.
P.S.
Can please some native speaker tell me how I can say something like "I did uncomment", but in correct English?
That sounds weird, but I don't know how it's right? Uncommented? I am talking about "setting a semicolonto the front of the line". That is "outcomment", or not?
Ok.
First Definition: ProbeTripped IS INP7
Second definition : ProbeTripped IS MEM217
This will not work because only one definition is allowed.
If something is defined as an input it can not be defined as a memory bit. The Wizard will also remove the definition as memory bit if you assign something as an input
Spartan117
This is what I understood from some comments in the src, too.
So I set a semicolon in front of that line. But after "outcommenting" that line with "... is MEM217", it threw out the next error, something with many IF and THEN I didn't understand.
And as I did not know what that does, I was afraid to just outcomment that, too.
This is why I asked here if that "two signals one input thing" could work at all, before changing things I don't understand, yet.
Pls write a Line
; Marc
before every line you change in the PLC, then it is faster for me to help you ;)
MainStage
; Configurable IO Section
; These I/O used to be in the wizard section below but are not
; selectable in the Wizard itself.
IF True THEN RST Custom ; M35
IF True THEN RST LockSpindle
; DO NOT MODIFY
; #wizardregion Configuration
IF True THEN RST BackGear
;IF True THEN RST ProbeTripped
IF True THEN SET ProbeDetect, SET ProbeDetectDisabled_M
If something is defined as an input like ProbeTripped it can not be in this stage, because the PLC can only set/reset memory bits, but no inputs
so it is correct to place a ; here.
try this one and see what happens if INP7 is switched,
I would expect ProbeTripped while homing :D
Marc_acorn_lathe_plc.src
(233.1 KiB) Downloaded 21 times
