Notepad Compiler Error
logix09
Post by logix09 »
I just finished setting up Notepad++ compiler, using the TB294 instructions. Every time i run a compile, I get this error:
Screenshot 2022-06-28 074823.png (2.53 KiB) Viewed 1835 times
I've checked the file location, and it is located in the C:\cncm directory. I've tried several different files in the directory and it keeps giving the same error.
Any help is greatly appreciated.
Re: Notepad Compiler Error
Do you have Windows set to hide file extensions? Is compile.cmd actually compile.cmd.txt?
logix09
Post by logix09 »
No, confirmed that it isn't compile.cmd.txt, and i can see all file extensions.
One thing that came to mind, was that I don't have admin privilege's. Would that stop it from compiling?
What are the contents of your compile.cmd file?
logix09
Post by logix09 »
cd \cncm
mpucomp.exe %1 mpu.plc
pause
eng199
Post by eng199 »
You are trying to compile "cncxmsg.txt". That is not a PLC program. PLC source will end with ".src". I am not sure why the error is about not finding a file, but I get the same message trying to compile ".txt" files.
logix09
Post by logix09 »
I am trying to compile Centroid-Standard-Mill-ALLIN1DC-ATC-Umbrella-r7.src
I get the same error when I try to compile anything.
Screenshot 2022-07-13 131421.png (3.27 KiB) Viewed 1737 times
What directory are you currently in, and what directory is the .src file in? Notepad++ cannot find the src file in the current directory.
logix09
Post by logix09 »
I see that. It is the local drive, in the cncm folder. Both the compile.cmd, and the src. file are in the same cncm folder.
I have this error on any PC not setup for CNC use. Maybe it is a problem with firewall/security settings on the PC.
