170 volt dc
JakesPorting
CNC Control System Serial Number: 1013141134
170 volt dc
Post by JakesPorting »
Ok so I am wiring and doing checks and I get 170 vdc out of the cap board.
The install manual states it should be max of 130 vdc is this going to be ok at 170 ?
Thanks Jake
Centroid_Liviu
Re: 170 volt dc
Post by Centroid_Liviu »
What is the revision on your install manual? We switched to 180V max cap-boards over a year ago. Please take at the Tech Bulletin below for specifics and serial numbers of when the switch happened.
http://www.ajaxcnc.com/downloads/Techni ... ns/269.pdf
JakesPorting
Re: 170 volt dc
Ok thanks I was just making sure don't want to blow anything up.
The revision on the install manual is 2-18-2014
