Acorn CNC12 v4.80 has been released. (8-12-22)
Re: Acorn CNC12 v4.80 has been released. (8-12-22)
This is the final version.
Any known bugs at this point? I keep running into what I believe to be a bug in the software.
I don´t think there are bugs on lathe and mill, both worked without issues on my machines.
I need to see if I can re-create the error. It results in the software abruptly closing while measuring a tool height. It happened 2x. The report doesn't capture anything however.
Post details about the cncpcCNCMaryland wrote: ↑Wed Oct 19, 2022 10:27 am I need to see if I can re-create the error. It results in the software abruptly closing while measuring a tool height. It happened 2x. The report doesn't capture anything however.
And freshreport.zip.
Operating System info:
Edition : Windows 10 Enterprise (10.0)
Version : 2009
OS Build : 19044.2130
Memory info:
Total physical memory : 17064079360
Available physical memory : 13923356672
Processor info:
Intel(R) Core(TM) i7-4785T CPU @ 2.20GHz
Number of cores : 4
Number of logical processors : 8
Single Thread Score of 1750
Version : 2009
Memory info:
Processor info:
Number of cores : 4
- report_F045DA7CBF8B-1030181290_2022-10-17_23-07-21.zip
- (800.93 KiB) Downloaded 11 times
run the communications stress test in the v4.80 /ncfiles directory.
more info on the tool touch off setup please.
