Z AXIS ON LIMIT SWITCH PROBLEM ALLIN1DC
Posted: Mon Jun 13, 2022 12:39 pm
Sorry but its me again,
Retrofitting 3 axis mill with a ALLIN1DC
Going thru the installation manual.
6.6 Homing the machine.
Problem occurred during installation and the set up of limit switches. x and y axis work perfectly ( hits limit and stops motion, runs other direction off of limit) switch).
z axis runs to the limit switch and stops correctly both directions, but when reverse direction to come off limit switch I get a" 411 FULL POWER WITHOUT MOTION"
SORRY BROGHT HOME LAPTOP FROM JOBSITE FORGOT IT NEEDS TO BE HOOKED UP TO THE UNIT TO DOWN LOAD REPORTS.
I will go back if you need more information
Regards,
Phil
Regards,
Phil
