Powertron Servo Motor
Posted: Mon Sep 01, 2014 6:32 pm
by JakesPorting
Hello all I'm looking into doing a upgrade on my Bridgeport Boss 8 R2E3 and i am trying to decide
if my servo motors would work with the kit or if i need to go ahead and replace them
The motors are Powertron pemanant magnet dc servo motor
Rated torque 30 lb. in.
rms amps 14.6
frame c402-3
max volts 146
max pulse amps 58.3 Model # 402cnsp0572
max rpm 6000
lb.in. amp 2.06
Kv .233 volts sec/RAD
tach volts 1000 rpm 7
I know that i will have to change the BEI encoders out but not sure on the servos if they will work
with the AI0DC ?
Thanks Jake
Re: Powertron Servo Motor
Posted: Tue Sep 02, 2014 7:21 am
by Centroid_Liviu
Those servos should work with the ALLIN1DC, it can handle DC servomotors up to 40 in-lb, 180VDC, and 15 amps. To figure out the encoder shaft size needed simply remove the end-cap off the back of the servomotor and measure the diameter of the shaft back there.
Posted: Tue Sep 02, 2014 6:48 pm
by JakesPorting
Thanks I will get things measured and figure my budget out and get with ajax about ordering.
