Z axis brake
danny
CNC Control System Serial Number: 0329160186
Z axis brake
Post by danny »
We have a problem where to connect the brake. We did find an output on the GIO4D labelled brake on the third axis however it does not activate on and off. We tested the enable and it did not activate also.
The inputs where wired according the manual. We are thinking that these outputs are not active when we are using the optically coupled drives Centroid AC/DC drives. From where can we get an output for the brake?
Regards
Daniel
Re: Z axis brake
If your PLC program is like the example I am looking at (gpio4d-acdc-basic-mill.src from the v3.12 release package), then it appears Centroid did not reserve any particular outputs for axis brake functions.
If you want an open-collector output (e.g. OUT19 on the GPIO4D axis #3 header), you could use that one, by adding the following line to your PLC program:
IF SV_PC_POWER_AXIS_3 THEN (Axis_3_Enable)
If you prefer a relay output (any otherwise-unused output, e.g. OUT15) then add a couple lines:
; in the Output Definitions section:
ZServoBrakeRelease  IS OUT15
; and in AxesEnableStage or MainStage:
IF SV_PC_POWER_AXIS_3 THEN (ZServoBrakeRelease)
danny
Re: Z axis brake
Post by danny »
HI .
Thanks again for your help !! Problem solved , Well done .
AMDlloydsp
CNC Control System Serial Number: 0605130770
Re: Z axis brake
Post by AMDlloydsp »
In that same vein, is there a way to only engage the brake after a fixed time delay after spindle-off?
Although it works, we don't like the R2E4 spindle brake. It's just too violent. Yet, we need it for tool changes.
So, we leave it completely manual. But it would be nice if one could time the application of it, so it only applies after the spindle has stopped (or nearly so).
Lloyd
