vfd drive
Posted: Tue May 20, 2014 10:51 pm
by littlerapids
I AM JUST STARTING A RETROFIT OF MY r2e4 BRIDGEPORT I have a 15 hp rotary phase converter running the rest of my shop (manual lathe Kearny trecker mill and what not) would it be advantages to install a vfd drive to run my machine and if so would it be better with a 240 single phase or a 3 phase input
Re: vfd drive
Posted: Wed May 21, 2014 12:57 pm
by Centroid_Liviu
Installing a VFD will also give you exact RPM speed control. Based on the model BP you have, the hp of your spindle motor is around 2-3hp?
Re: vfd drive
Posted: Wed May 21, 2014 8:45 pm
by bloomingtonmike
Have you measured the voltage on each leg of your RPC? Is it balanced? If not and with only 2-3hp need probably I would not risk using the wild leg on the VFD input as there is no real benefit. In fact it will cost you more per kw as the ideler is running during usage of the RPC.
Re: vfd drive
Posted: Fri Jun 13, 2014 12:46 pm
by AMDlloydsp
We converted our R2E4 to single-phase with ease (even BEFORE we bought the Centroid control, when we were still running on the BOSS-9 control). No need to keep that roaring converter going!
LLoyd
