Oak for 5 Axis Machine
Posted: Mon Mar 07, 2022 9:58 am
by mdhubilla
This is a training machine I built for students running on mach3. Replacing the controller to oak amd servo motors compatible with oak, is it feasible to upgrade this machine with cnc12 and Oak?
Thanks.
Re: Oak for 5 Axis Machine
Posted: Mon Mar 07, 2022 11:50 am
by cncsnw
Yes.
You would probably need a larger enclosure.
You will need an OpticDirect board to interface to the 5th axis (the first four axis interfaces are built into Oak).
If you want to run simultaneous 5-axis toolpaths, you will need the "Contouring" version of CNC12 (CNC12-C), which costs extra and requires that you submit export-compliance paperwork.
Absent the Contouring software, you can still control five axes, you just cannot move them all simultaneously.
Posted: Tue Mar 08, 2022 6:12 pm
Hello. we are working on a new cnc controller board that would be ideal for this machine called the "AcornSix" if you can wait a while the AcornSix would be the cost effective way to go for this machine.
Posted: Sun Apr 10, 2022 5:43 am
by LauriLinna
Hi, I'm designin diy 5-axis (simultanius) router. Im planning to use closed loop stepper motors. When is this AcornSix board ready? Can you tell us some specs for it?
Posted: Mon Apr 18, 2022 5:09 pm
LauriLinna wrote: ↑Sun Apr 10, 2022 5:43 am
AcornSix
Maximum number of Axes: 6
3 Incremental Encoder and Scale Inputs: Encoders
(A, B, and Z channels)
Control Interface: 100 Mb/s Ethernet to PC
Built in Digital PLC Inputs: 16
Built in Digital PLC Outputs: 16
Analog or PWM Outputs: 2
Analog Output resolution: Up to 16 bits
Dimensions (W*D*H): 8 * 12 * 0.75 inches
