Suggestion about videos
In some of Marty's videos he inserts a video in a PnP (picture in picture) scenario. When I watch the videos it is difficult to follow the logic as we are watching the inserted video upside down. This means when Marty says move left to right his hands in the video are moving right to left and + and - are reversed to how they would be if we were facing the mill. I took the liberty of grabbing a short section of a video and correcting the insertion. The video is 1:50 seconds long showing first how it is uploaded to YouTube and then the same section with the corrected insertion. Let me know if you all agree. This is only meant as a suggestion not a criticism. These things are sometimes hard to grasp and we(I) need all the help we can get!
Re: Suggestion about videos
The original video was correct. You should be thinking of the spindle moving relative to the work piece, not the work piece moving.
Your flipped video is the wrong logic. you are thinking of the table moving left to right being +x but it is not. That means the spindle is moving right to left which is actually -x
Your CAM follows the same logic. Everything is in relation to the spindle moving relative to the workpiece.
I understand that but in the original when he says left to right his hand is going right to left to the viewer of the video. That is what is confusing and hard to follow. I understand about the table movement and which direction the table should move in + or - relative to the spindle. What he says is correct it is just hard to follow with the inserted video upside down. It is as if the viewer is behind the mill not in front of it.rk9268vc wrote: ↑Thu Feb 03, 2022 5:33 pm The original video was correct. You should be thinking of the spindle moving relative to the work piece, not the work piece moving.
see page 76 and 77 of the Acorn installation manual.
and related.
https://centroidcncforum.com/viewtopic. ... 437#p28437
and related.
To be clear. I know which direction the table must move for the correct + and - moves. The only point of my posting was to point out that the video would be easier to grasp the intent if the viewer was looking at the insert in the same aspect as the presenter. As if looking over the shoulder of the presenter. That is all. So when Marty said left and moved his hand left the viewer was seeing Marty's hand move left. That is all. As it stands now to the viewer when Marty is moving his hand left the viewer sees that hand move right. It distracts from the teaching aspect. No big deal, just a helpful hint.
You are correct Black Forest. It is far more intuitive to teach from the users perspective when he/she is standing in front of the machine.
