Schematic templates available?
clough42
CNC Control System Serial Number: 80F5B5F561AB-1001215267
Post by clough42 »
I am getting ready to document my Acorn/Ether1616/Avid/Clearpath build on my YouTube channel, and people are already asking me for schematics. Is there a standard template available that I can use to draw them up? I see that all of the schematics on the web site use common components, but I didn't see a template available anywhere.
Re: Schematic templates available?
The schematics are available in both PDF and CAD format. When you download the schematics you get both formats. I use the CAD drawings and edit them to the machine that I'm retrofitting. Just pick the one that is closest to your system and edit. With the CAD drawings you can create CAD blocks for each component and create any custom schematic.
lavrgs
Post by lavrgs »
what program are you using to open the CAD?
RogDC
Post by RogDC »
The multiple SDSK schematics should be current on the website. The PDF wiring diagrams were in a zipped file, now they are individual PDFs for download. Link to documents at the bottom of the Centroid CNC Website: https://www.centroidcnc.com/centroid_di ... nuals.html
Here is a discussion on the latest resistor values: https://centroidcncforum.com/viewtopic. ... 292#p47292
Are you planning on using the CNC4PC board or wiring direct to the Acorn and Ehter1616? I personally cannot recommend the CNC4PC board based on my past experience with it, some have had success and there is a newer version released.
I ended up re-configuring and wiring my Avid 3 axis 4 motor to the Acorn and Ether1616 using the latest wiring diagram to use auto-squaring and individual motor fault indicators.
rk9268vc
Post by rk9268vc »
clough42 wrote: Thu Feb 03, 2022 10:58 am I am getting ready to document my Acorn/Ether1616/Avid/Clearpath build on my YouTube channel, and people are already asking me for schematics. Is there a standard template available that I can use to draw them up? I see that all of the schematics on the web site use common components, but I didn't see a template available anywhere.
There are .DWG drawings in the hookup schematics zip that is found under "hookup schematics" on the main acorn page (not forum)
Fusion is terrible at opening autocad .dwg's
I opened the clearpath schematics in solidworks and saved them as a .dxf for you. Fusion can open that, but is spotty with text because it is on a different layer
Give these a try. :)
Clearpath_With_multiple_motors.DXF
(2.59 MiB) Downloaded 49 times
Clearpath_WithCNC4PC.DXF
(1.3 MiB) Downloaded 54 times
rk9268vc
Post by rk9268vc »
Forgot to mention that ExpressSCH is my preferred way to do schematics for free. I have most of the components drawn up as "components" objects for expressSCH. If you go that route, let me know and I can send over those for you. I dont have them on this pc
lavrgs
Post by lavrgs »
It may be better to have the drawings in DXF format...not sure if that would allow mods. I have Creo and will trying to see if it will open them...which I consider unlikely.
lavrgs wrote: Thu Feb 03, 2022 12:18 pm what program are you using to open the CAD?
I have and use AutoCAD 2016. Opens the DWG files just fine and I can save as a DXF if needed.
rk9268vc
Post by rk9268vc »
ShawnM wrote: Thu Feb 03, 2022 6:07 pm I have and use AutoCAD 2016. Opens the DWG files just fine and I can save as a DXF if needed.
Be aware that autocad saves layers in the dxf. like if the drawing is 5 layers, the dxf will have 5 layers.
If you end up resaving, see if there is a way to save everything as one layer. :)
This is a problem with other cad software which can sometimes only grab one layer, so you will only get some of the lines brought in. Especially with fusion where it wont let you pick which layer to bring in like solidworks does.
we use DraftSight to create the schematics.
