I am having trouble with the Soft Limit values in the table resetting themselves to zero after I shut down the computer and bring it back up
I am using Centroid 12 v 4.64 on a home built router table
I have been using Centroid for several years now, with my all-in-one setup on my Boss 6 so I am familiar with the set up procedure,
and yes I do hit F10 after putting them in to save them.
The problem does not occur if I just shut down the software and restart, I have done it hundreds of times during the set up process.
It only seems to happen on reboot.
I have tried setting them both in the Wizard, and the Config screen with the same results.
Any thoughts on this?
Soft Limit Values Reset to 0
- CNC Control System Serial Number: GHFDDHECE(0223151234)
Re: Soft Limit Values Reset to 0
Pro License???
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Edited:jonmessenger wrote: ↑Sun Jan 23, 2022 12:49 am I am having trouble with the Soft Limit values in the table resetting themselves to zero after I shut down the computer and bring it back up
(Please) post a fresh report when asking for help.
Are you using auto squaring by chance and the auto square cycle not completing properly? If so, that may be your problem.
Otherwise, give exact steps that you are going through (along with your report) so that it can be recreated.
You know what Marty, I don't like people yelling at me, even on a forum post. So Ill tell you what I am going to do, I will solve this riddle myself like I always do and I won't be back here to trouble you all again.
Cheers
Cheers
My apologies.
I'll stop using the word always.
The report tells us how the control is configured.
Some of can load the report and try and spot things that will help the user.
Many if us spend a lot of time trying to help others
All I ask is that when a user asks for help, is provide the information so we can help provide good suggestions.
marty is trying to help you. if you would like good answers you've got to provide good information and the best way to do that is post a fresh report.zip. we have no idea how your system is configured and can only guess at what the issue may be.
one guess is that you are using Paired Axes with Autohoming and do not have a Pro License installed or maybe you interrupted the homing program mid cycle.......but that is just a wild guess as we have no report.zip to look at.... that report.zip would give us that information.
yes it seems like a simple question from your end.. but please look at it from our perspective we have no idea what axis motors and drives are being used how they are wired and configured, even what kind of machine... not all 'routers' are the same, how is homing setup? no homing? manual homing? auto homing? auto homing with squaring? , travel limits in use?, what type of switches are used? , where are they located?, how are they defined in the PLC/Wizard? , how are the axes setup?, is one axis paired to another?, is there a custom home program in use? , what are the CNC12 error messages? etc..etc.... all this information is contained in the report.zip file and is relevant to solving your issue in a timely manner.
(When i built this forum i considered making it mandatory to post report.zip when posting a tech support thread because the information is so critical to solving any issue.)
we are here to help..please review the posting guidelines here and help us help you with your project.
