Hi
Making my way through the wiring on my CNC Lathe and i had a quick question on the Spindle OK input. My VFD has quite a few settings for this relay, is it just a simple Run command on the normally closed side?
Cheers
Quick question - "Spindle OK" input <resolved>
Re: Quick question - "Spindle OK" input
No. If SpindleOk is not "made", it's a fault [1]. It can be inverted if needed
Thank you for the quick reply, seems really obvious now you've told me.
Re: Quick question - "Spindle OK" input <resolved>
Just to follow on from this, i'm looking at the wiring diagram "S14987-ACORN_rev4_4_BIT_GRAY_CODE_TURRET_LATHE_STANDARD_CONNECTIONS" (Please see attached)
Why do you need a Drive OK and Spindle OK?
- S14987-ACORN_rev4_4_BIT_GRAY_CODE_TURRET_LATHE_STANDARD_CONNECTIONS (1).pdf
- (152.66 KiB) Downloaded 52 times
Drive OK is for the axis drives and Spindle Ok for the Spindle
Thank you i just wanted to double check. My Stepperonline DM556T's don't have that output so that free's up some I/O
