Hi everyone,
I am attaching a laser to my router. When I go a M37 the spindle will start spinning and I will get nothing from the laser. As far as I can tell I set everything up correctly. Any advise would be great.
Router + Laser
- CNC Control System Serial Number: 3699, 3788
Router + Laser
- report_E415F6F96E67-1005203788_2021-12-01_16-35-26.zip
- (698.25 KiB) Downloaded 56 times
Re: Router + Laser
It looks like you have the outputs in the wizard set up right. Double check your output/relay connections for your type of laser. M37 should turn off the spindle, set 0 rpm, and turn on Output 4 (laser Enable) as well as flick Output 7 on/off (laser Reset).
Edited; Also, do you have PWM enabled in the Wizard?
Scott
