Hello Everyone,
While starting a programming solution for a part, I noticed you could select a machine type under Setup in Fusion360. Curious, I searched the list and did not find Centroid in the list. I selected a generic type (x,y on the table, z on the head). I think it would be great marketing for the little guys who use Acorn to be able to select a Centroid Acorn machine type.
Regards,
Brian
Fusion360 Machine List for Centroid/Acorn
Re: Fusion360 Machine List for Centroid/Acorn
What is the Centroid Acorn "type"? Is it a knee mill with the quill powered or the knee powered? A plasma table? A router? A lathe with a C axis? A horizontal boring mill? Perhaps a laser cutter?
The beauty of Centroid's products is they can be used to retrofit a large variety of machines, many that we're not even originally CNC. A recent thread described a pen plotter application with Acorn.
This is one time you should take the verbiage "machine type" literally. As in machine type not controller brand.BGracia wrote: ↑Sun Nov 28, 2021 2:30 pm Hello Everyone,
Regards,
Brian
- CNC Control System Serial Number: 0479B7ABD46B-0319203088
That's the beauty with Acorn, every machine is different and uniqe.
You design your own customiced machine in Fusion, with the dimentions(capacities), feeds and speeds+ another additions and postprosessor you preffere.
CW
CW
Bridgeport J-head retrofit
Just for fun
Just for fun
The Machine type is for defining the spec of the machine such as table size, max speed, spindle rpm range. The Centroid Acorn is made to retrofit or custom builds, so there will not be a reference in most cases. unless you retrofitted a known machine like a Fadal etc. The Machine selection is not required to use Fusion it is just handy as it helps with warnings if you say to try and cut something bigger than the defined table size etc. For the post-processor selection, you would pick Centroid and it is listed in fusion.
Think of it like a computer the machine list would define how much ram, what CPU. how much hard drive space Etc. well, the post-processor is like then defining the software on the hardware I.E windows7, Linux, IOS, etc
It's too different things, The Default/generic profile is easy to change and match your parameters in fusion. If you need help with a machine definition let me know.
