Conecting old fanuc dc drive
- CNC Control System Serial Number: 00P8DC111213-01+4211082
Hello , good nigth for all
I have robot drill of fanuc and I buy a centroid oak cnc control.I will use the the old dc servo motor 5m and 10 m
I want to use rhe old DC drive but I need some information how to wiring it to the oak centroid control
This dc drive is A20B-0009-0320 fanuc.
Thank you for all information you can say me
Thanks : Rafael Almanzar
Re: Conecting old fanuc dc drive
If I am thinking of the right Fanuc drive...
The drive requires a tach input. Some extra hardware is needed to generate tach signals for the drives. Centroid did a few systems like this, but the results were not too good. The systems were more complicated than most and several drives failed within a few months. Maintaining the antique drives quickly became more expensive than replacement would have been. Centroid no longer offers the special hardware needed to reuse the old Fanuc drives.
Thank you eng199
I see in the maitenance drawing manual
The pin #6 and #19 (TSA -TSB) are for that funtion
(Tachogenerator feedback signal)
I' m dont be sure were about the connection with the oak and drive
Without providing a manual for the drive, we can't help you. Many of us have not worked with that drive. Having the manual will be of help, and Centroid or one of the more experienced users might be able to make suggestions.Rafael Almanzar wrote: ↑Wed Nov 17, 2021 11:06 am Thank you eng199
Did you research this before you bought OAK? Did you buy the flying lead data cables from Centroid as well?
In the end, you are the integrator, its your responsibility to have made sure the drive would be compatible with Oak.
Hello , marty
Yes, I buy the flying cable and the dealer of centroid say me is posible wiring those Items
The manual is (the fanuc 6m)
Pin 1- PRDY 1
Pin 2- ENBL 1
Pin 3- OVL 1
PIN 4 VRDY 1
PIN 6 TSA
PIN 7 VCMD
Pin 14 PRDY 2
PIN 15 ENBL 2
PIN16 OVL 2
PIN 17 VRDY 2
PIN 19 TSB 2
PIN 20 E
PRDY 1-2 positiln control raedy Segnal
ENABLE 1-2 firing control signal
OVL 1-2 overload signal
TSA-B tachogenerator feedback signal
VCMD velocity command signal
Those are all conections of the CN 1
Im dont know how to send adjunt data
Thank you : Rafael Almanzar
Pin 1- PRDY 1
Pin 2- ENBL 1
Pin 3- OVL 1
PIN 4 VRDY 1
PIN 6 TSA
PIN 7 VCMD
Pin 14 PRDY 2
PIN 15 ENBL 2
PIN16 OVL 2
PIN 17 VRDY 2
PIN 19 TSB 2
PIN 20 E
Do you have a web link to the manual? Do you have it in electronic format you can upload? You click on Full Editor and Preview, then click on the ATTACHMENTS Tab, then click on Add Files, a dialog box will pop up and you simply point to where it is at on your computer, then click OPEN in the lower right corner of that dialog box.
Who is the dealer that told you it would work? Same person you bought OAK and the Flying lead cables from? If so, you should be talking to him.
I can't tell you if it will or if it won't work. I don't have experience with that drive. I do know if you can upload the manual or provide a link, the more knowledgeable can look at it and give you better advice. Those pins you are providing, I am not so sure are enough information.
Yes marty is the same person but hi let me alone
I dont remenber the link of manual
Marty , send to me you email for send you the manual
