Help! No Virtual Jog Panel when starting cnc12 *SOLVED* set screen resolution to 1920×1080
CivilCNC
CNC Control System Serial Number: will obtain
Post by CivilCNC »
ImageWhen I start cnc12 it loads in full screen with no virtual jog panel.
Even when I try to open it from the toolbar it doesn't pull up into position on the right hand side of page. When I hover over the VCP on toolbar its blank, and Grey. Thanks in advance
Upnorth
Re: Help! No Virtual Jog Panel when starting cnc12
Post by Upnorth »
ALT J should turn on the virtual jog panel.
ZZBOB
CNC Control System Serial Number: 20915A (1124081904)
Post by ZZBOB »
HI THERE..
Check the link....
Win.10 tablet mode...
VCP-options...
Restart computer...
CivilCNC
Post by CivilCNC »
ZZBOB wrote: Wed Oct 27, 2021 5:11 am HI THERE..
Check the link....
VCP-options...
Restart computer...
What link are you speaking of?
I did check tablet mode.
Whats VCP options can I change?
ZZBOB
Post by ZZBOB »
OK..try this...
DO a search NO KEY PAD.....
Windows is most likely in tablet mode which causes this.
CivilCNC
Post by CivilCNC »
Upnorth wrote: Wed Oct 27, 2021 4:58 am ALT J should turn on the virtual jog panel.
This is what it looks like when I hit alt-J, there is no VCP options to select from this window- also it doesn't appear to be functional at all.
It comes up but way different
CivilCNC
Post by CivilCNC »
cnckeith wrote: Wed Oct 27, 2021 1:40 pm Windows is most likely in tablet mode which causes this.
Never in tablet mode
CivilCNC
Post by CivilCNC »
ZZBOB wrote: Wed Oct 27, 2021 1:21 pm OK..try this...
I'm not able to access VCP options thru the vcp, because the VCP never shows up for me.
post a fresh report.zip
