Millright Mega V Plasma Table
Re: Millright Mega V Plasma Table
Movement Range, Standard Model: 485mm x 500mm x 95mm (19”x19.6”x3.75”)
Movement Range, XL Model: 890mm x 890mm x 95mm (35”x35”x3.75”)
X and Y Rail Dimension: 100mm x 60 mm with up to 8mm thickness (3.94” x 2.36”; up to 0.315” thick)
Z Rail: MGN15 Linear Profile Rails
Bearing Wheel: 40mm Acetron (1.57”) with dual 608-2RS bearings
Router: 120V 1.25 Horsepower DeWalt DWP611
Power Requirement: 120V.
Homing Switches: X, Y, Z
Electronics box: Laser Cut, brake bent, welded, pre-solder, and pre-assembled
Bearing Plates: Precision Cut 6.35mm (0.25”) Steel
X Axis Total Motor Torque: 270 ounce/inch
Y Axis Total Motor Torque: 540 ounce/inch (note this is 2 motors)
Z Axis Total Motor Torque: 270 ounce/inch
A Axis (Optional) Total Motor Torque: 270 ounce/inch
Digital Stepper Driver Max Amperage: 4 Amps/phase 5605D2
X Axis Resolution: 0.013mm (0.0005”)
Y Axis Resolution: 0.013mm (0.0005”)
Z Axis Resolution: 0.005mm (0.0002”)
A Axis (Optional) Resolution: 0.028 degrees
X Axis No Load Accuracy and Repeatability: 0.025mm per 300mm (0.001” per 12”)
Y Axis No Load Accuracy and Repeatability: 0.025mm per 300mm (0.001” per 12”)
Z Axis No Load Accuracy and Repeatability: 0.0076mm per 100mm (0.0003” per 4”)
A Axis (Optional) No Load Accuracy and Repeatability: 0.05 degrees per 360 degrees
X Axis Rapid Rate: 16,510 mm/min (650 inches per minute)
Y Axis Rapid Rate: 16,510 mm/min (650 inches per minute)
Z Axis Rapid Rate: 4,570 mm/min (180 inches per minute)
A Axis (Optional) Rapid Rate: 21,600 degrees/min
Maximum Cutting Feed Rate: 12,700 mm/min (500 inches per minute)
X Axis Acceleration: 0.15 G Force
Y Axis Acceleration: 0.15 G Force
Z Axis Acceleration: 0.07 G Force
A Axis Maximum OD Chuck Capacity: 25.4mm (1”)
X and Y Axis Drive Mechanism: Precision 20 Diametral Pitch Rack with Hardened Steel Pinion
Z Axis Drive Mechanism: Lead screw with anti-backlash nut
A Axis (Optional) Drive Mechanism: Closed loop GT2 Timing Belt
thanks for posting the photos.
our test bed machine had direct drive pinion like the machine you have, while this worked, we ended up putting a $200 5:1 gear box on X and Y axis and got better motion (smoother cuts) out of the machine.
- Plasma/Laser Lead
Here's the 5:1 Gear boxes on the X and Y axis. 2 for the paired Y axis and 1 for the X axis. (FYI the overall turns ration on the X and Y axis is 1.32639 which is a nice compromise between speed and accuracy)
Gear box was not needed for the Z axis as it is ball screw driven, direct drive 2.5 turns per inch which is right in the sweet spot for a plasma machine.
So adding the 5:1 gear box reduces the work the stepper motor has to do and gave you better cuts!! … I’ll have to look to see if I can find them and see what it’ll take to convert! I do have a question. When I get my acorn board I want to get another stepper driver and run the 2 Y axis motors separately for auto squaring. But also keep my 4th rotary axis I believe the acorn does this? (Auto squaring with rotary?)
Never mind I answered my own question
https://www.centroidcnc.com/centroid_di ... _guide.pdf
the Acorn axis pairing documentation link is below...it shows what we inherently support. this is not the only way to do auto squaring, it is just what we officially support.. the short answer is that you'd need 5 axes under cnc control to have our as supplied software do software auto squaring AND a rotary axis. we are working on a six axis version of the Acorn so Acorn users can do stuff like that.
related.. "toaster" on the forum has written his own auto squaring macro that is pretty nice.. i will probably update ours to something similar in the future.
Good afternoon noon Keith, I received the boards today, it looks like I have everything except I need 2 green connectors. I have one included that goes to the power supply, although I need one that’ll hook up to the plasma cutter voltage etc
Looks like I found them plugs on Amazon, I’ll get the plug. It should be here Monday. (I wasn’t sure I could find them Google lens is amazing!
sorry about that..will send you some asap if you have already ordered, please advise.
I bought them no problem. I’m hooking up the box today. If I remember correctly the guys on the forum recommended to hook the wires from the drivers to a db25 instead of directly to the acorn board. I’m not sure why that is… I ordered a db25 and it’ll be here in a couple days. I’ll have to look into how you hooked up your thc boards. See if you have pictures on that.
A couple questions.
1 would it benefit any if I changed the wires from the steppers to shielded wires? (I have them) limit switches also?
2 I’ve seen that you should run a ground from the machine to an earth ground.
3. Thc boards where to mount.
4 (from above) db25 board needed?
Sorry pretty loaded post.
A couple questions.
